1999 Other Jeep Models Need help to replace the water pump
1999 JEEP
70,000 MILES • 4 CYL • 4WD • AUTOMATIC
JACK-SCHOLZ
I would kike to replace the water pump. Some questions: 1) What are the exact steps? Is there a video available? 2) Do I need to take the shroud out? 3) There seems to be a hose tube attached to the water pump, where would I get this part?
Dec 22, 2008 at 4:48 AM
RACEFAN966
  • 5,029 POSTS
Ok luck has it for you that I own one and have replaced it. So first on the right side (passanger side) there is a drain for the radiator on the bottom start with draining it. Now you have to remove the fan shroud and then you need to get a fan clutch tool to remove the radiator fan and clutch (call to your local parts store to see if any of them rent it. Now you need to remove the lower radiator hose and there is a heater hose connected to it. Take of the fan and fan clutch then remove the serpentine belt (buy a new belt while you are there unless it is fairly new already). I also found it easier to remove the upper hose and the thermostat housing so replace the thermostat while you are there. Now you will need to remove the bolts that hold the water pump on and remove the pump. Clean the surface on the engine and put some sealent on it and on the water pump put the gasket on the pump and go in reverse order. I did not remove the radiator when I did mine but it make a lot more room if you do. Hope this helps if you get a repair manual it will show you pictures too I like haynes manuals and some like chiltons you might want to check with your local library so see if they have one you can check out. Hope this helps if you need anything more just ask. Thanks and Merry Christmas.
Dec 22, 2008 at 9:37 AM
JACK-SCHOLZ
To racefan966, thanks for your detailed answer. I drained the system using the drain. I disconnected the upper two bolts for the shroud. I disconnected the upper radiator hose from the radiator, I took the serpentine belt off and the idle pulley. For some reason this jeep (grand cherokee laredo 99) does not have a fan clutch, just an electric controlled cooling fan. I guess that makes things easier. Now my questions: 1) On the left lower side of the radiator I see the lower radiator hose going to the water pump. Do I have to disconnect better here or at the water pump? 2) Again, on the lower left side of the radiator, there are two smaller rubber hoses leading to metal hoses, leading to ??? Do I have to disconnect those as well? I have some pictures attached. 3) Do you know any trick-of-the-trade how to loosen the rubber hoses once the clamp has been removed? Thanks.
https://images.2carpros.com/forum/automotive_pictures/290331_100_1044_1.jpg
https://images.2carpros.com/forum/automotive_pictures/290331_100_1049_1.jpg
Dec 23, 2008 at 8:17 AM
RACEFAN966
  • 5,029 POSTS
Oh yea you have a 4cylinder there is no engine fan other then electric so dismiss the fan removal. Now on the lower hose I usually disconnect it from the water pump only unless I am going to replace it. As for getting them loose I us a screw driver to break the seal (putting it between the hose and the pump) and twist and pull at the same time. The other two hoses if they are not in the way of getting the pump out then I would leave them alone. Hope this helps anything more just ask.
Dec 23, 2008 at 1:35 PM
JACK-SCHOLZ
Your conclusion is that I have a 4 cylinder engine because I don't have a fan clutch? I'm getting worried that you are an expert overall. There are no 4cyl engines. Did you mean 4 Liter?
Dec 24, 2008 at 1:41 AM
RACEFAN966
  • 5,029 POSTS
Ok there is a 2.5 ltr 4cyl option (in the standard cherokee) which you stated in your original question it says 99 jeep 4 cyl, now on the grand cherokee it was either a 4.0 ltr 6 cyl or a 4.7 ltr V8. Now a 4.0 ltr is a 6cyl. I have a 99 4.0 ltr 6cyl and yes it does have a engine fan as well as an electric for the a/c. So if you do not have an engine fan on the engine then just minus that part the rest is the same. Now answwer this is it a 4.0 ltr or the 4.7 V-8? So if there are any more question ask.
Dec 24, 2008 at 10:30 AM
JACK-SCHOLZ
Sorry for the mix-up. You are right for the Laredo. I always keep forgetting that there is a "regular" Cherokee. My car is a Grand Cherokee Laredo with 4 ltr. 6Cyl Engine.
The other two hoses you see in the pictures are also connected to the radiator and seem to come from the heating. I believe I would have to disconnect them as well?
That's my final question. Merry Christmas!
Dec 25, 2008 at 1:59 AM
RACEFAN966
  • 5,029 POSTS
Only if you plan on removing the radiator, other wise no need to.Thanks and have a Happy New Year.
Dec 26, 2008 at 1:24 AM
