Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Other
Engine
Symptoms
Idle Rough
1999 Other Jeep Models idle
1999 JEEP
99,000 MILES • 6 CYL • 4WD • AUTOMATIC
BYRONHAYNES
MEMBER
1 POST
idles roughs and sometimes idles real fast whether cold or hot engine.
May 1, 2008 at 7:51 AM
BLACKOP555
Experienced Mechanic
i would suspect a vaccum leak or maybe a sticky EGR valve since its only once in a while the high idling.
if those all check out good check the pcv valve, if its good it should rattle.
if all else fails probably a dirty throttle body or bad IAC module.
May 1, 2008 at 11:46 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine — Idle High
