1999 Other Jeep Models idle
1999 JEEP
99,000 MILES • 6 CYL • 4WD • AUTOMATIC
BYRONHAYNES
idles roughs and sometimes idles real fast whether cold or hot engine.
May 1, 2008 at 7:51 AM
BLACKOP555
  • 10,386 POSTS
i would suspect a vaccum leak or maybe a sticky EGR valve since its only once in a while the high idling.
if those all check out good check the pcv valve, if its good it should rattle.
if all else fails probably a dirty throttle body or bad IAC module.
May 1, 2008 at 11:46 AM
