1999 Other Jeep Models CRANK SHAFT SENSOR LACATION
1999 JEEP
120,000 MILES • V8 • 4WD • AUTOMATIC
CJROTH27
MEMBER
1 POST
Where is the crank shaft sensor located on my 1999 Jeep grand cherokee? thanks
Feb 19, 2010 at 1:18 AM
✓Experienced Mechanic
On right side of engine block,above starter motor.
Feb 19, 2010 at 9:11 AM
RIPNDR27
MEMBER
I just did this a few moment ago. It is located behind the starter.Look just behind the transmission on the passenger side. It is hidden quite well as I found out, but once you remove the starter, you will see it very clearly. What problems are you having with you vehicle?
