1999 Other Jeep Models Check Engine Light - Transmission Rel
1999 JEEP
99,000 MILES • 6 CYL • 4WD • AUTOMATIC
SWATAZ
  • 11 POSTS
Ok I am probably not going to like the answers I get but here is the lowdown on my 1999 WJ 6 cyl., 42RE Tranny.
Got an engine code today on the way back to work after driving a few miles to my home for lunch
The light wasn't on this AM on the way to work, nor was it on last night when I shut it down for the evening.
The code: P0783 - 3-4 Shift Sol / No RPM Drop at Lockup
My understanding is the OD solenoid doesn't engage and help the OD come on, therefore helping with fuel economy, etc... correct me if I am off base though!
Factors and history:
* Cold tranny doesn't smoothly shift into 3rd gear normally. Warm, shifts just fine. Was told that this could be a clutch pack issue.
* Used the Full time 4WD for the first time in the snow last night
* Light appeared shortly after going through massive amounts of flooding water on the roads.
What is the culprit?
a) The OD solenoid
b) The clutch which is now shot b/c I HAD to use the 4 x 4...therefore straining an already malfunctioning tranny
c) The Water impacting the solenoid, causing it to temporarily malfunction
Yeah I know I am clutching at straws with the last one, but I am desperate to NOT spend huge bucks....
Funny thing is? It seems to run and shift just fine. Is this something I should be able to feel?
Could this be temporary and the code gets flushed after a few cycles?
Any insights would be greatly appreciated.
Feb 13, 2008 at 3:34 PM
PS2PLAYA
  • 9 POSTS
diconnect the battery to reset trouble codes reconnect battery and make sure to unlock drivers door after reconnecting battery to reset system recheck for code.
Feb 16, 2008 at 1:48 AM
SWATAZ
  • 11 POSTS
[quote:392c7a01a3="ps2playa"]diconnect the battery to reset trouble codes reconnect battery and make sure to unlock drivers door after reconnecting battery to reset system recheck for code.[/quote:392c7a01a3]
Thanks...
Actually, the code got kicked on Friday evening as whatever was throwing the code ceased to be interpreted as a failure. So, no more Check Engine light for me.
My guess is that something got doused going through that huge puddle of water and didn't like it.
I still have to deal with my 2nd to 3rd gear clutch pack seal issue though I bet... ;-)
ON EDIT - The light is back. Now I have to assuem it is an intermittent problem.
Feb 17, 2008 at 3:12 AM
