1998 Other Jeep Models Engine-cracked head gasket
1998 JEEP
MKRAKOVIA
Engine Performance problem
1998 Other Jeep Models V8 Four Wheel Drive Automatic 140k miles
I cracked my head gasket/cylinders and they told me they could rebuild my engine but it would cost around 2500$. I was just wondering if that is a reasonable estimate, or if I should take it elsewhere. I found a used engine with low mileage on it for under 1000$, what is a fair price for installing the motor if i decide to do that?
it is a 5.9 liter 360 small
Apr 28, 2010 at 12:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
replacing your vehicles cylinder heads should only cost around $1,500 .. that is $1,000 for labor and $500 for both new heads / gaskets.
it will cost around $750 to remove and replace the entire engine assembly, plus the $1,000 for the engine which is $1,750.
i would go with replacing the entire engine for that price over just the heads and I would definitely consider taking it to a different shop, first shop seems well overpriced..
Apr 28, 2010 at 12:35 PM
