You may have a vacuum leak, get a can of spray throttle body cleaner, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If that doesnt do it, you may need a new idle air control valve, it's bolted to the throttlebody.
IAC's dont clean up as a fix! If it's the problem, replacing it is the only fix.
SPONSORED LINKS
Saturday, May 9th, 2009 AT 9:24 AM
