1998 Other Jeep Models car pulling to one side
1998 JEEP
153,000 MILES • 6 CYL • 4WD • AUTOMATIC
TYBABY71
i have a jeep grand cherokee while in motion my car pulls to the left and it also has a hesitation as if one wheel has the brake ingaged could you please tell me what could cause this?
Feb 9, 2009 at 4:48 AM
  • 75,988 POSTS
DRAGGING BRAKES
May create a steering pull and/or increased fuel consumption. Caused by weak or broken retracting springs on drum brakes, a jammed or corroded caliper piston, a floating caliper with badly corroded mounting pins or bushings (uneven pad wear between the inner and outer pads is a clue here), overextended drum brake self-adjusters or a sticky or frozen emergency brake cable
Feb 9, 2009 at 5:29 AM
