1998 Other Jeep Models 1998 Jeep Grand Cherokee TSI Elictric
1998 JEEP
EVILJEEPTSI
Electrical problem
1998 Other Jeep Models V8 Four Wheel Drive Automatic
The run down:
1997 Jeep Grand Cherokee TSI V-8 4X4
The jeep runs great at all speeds, as well as the transmission. It is pretty much sound mechanically. But electrical y it is evil.
The dash gauges do not work. The interior Lights will not go off. The power windows will not work on any door. I had to remove the interior light fuse just to get them to turn off. When you put the fuse back in, the relay clicks repeatedly, then seems to quickly drain the battery. It SEEMS that as long as the fuse is out the battery stays charged.
The radio and fan both work. The power seats work as well. The information center on the upper console and the larger display information center that has a digital picture of the jeep located near the shifter both light up, but display no information (outside temp, compass, etc.), just hyphens. The bottom info center that has a picture of the jeep will not show that a door is ajar when it is.
I have checked all fuses and circuit breakers, but all are good.
I have taken it to two shops that gave up and told me to come pick it up (I figure because they did not want to mess with it). The third shop I took it to told me that the BCM would not communicate. And that I would have to buy a new BCM at the dealership and have the dealership program it to my jeep. I took it to the dealership and had the new BCM installed. They told me that it made no difference and that it was still not communicating. Why would a new BCM not even communicate? The problem must be before the BCM.
The dealership said that they will not do anymore diagnostics on it because it has been gone through by too many other shops. All wires that have been messed with are still in-tact though. I am to the point to where I am willing to dismantle the dash and dig in. But if I could get some ideas on how to go about this, I would be very grateful.
Please note that the lights behind the gauges do work just not the needles themselves.
So after over $1000 of spending I still have the same Jeep I did at the start of all this. I cannot take it to anymore shops as I will probably end up spending all together, more than the Jeep is worth.
Could this be an ECM/PCM issue?
Aug 12, 2008 at 1:13 PM
RACECARFL
I have the same problem with a !999 Grand Cherokee, have you found any fix for it yet ?
Aug 25, 2008 at 1:14 PM
