1997 Other Jeep Models not sparking
1997 JEEP
XOX_MEGZ_XOX
1997 Other Jeep Models 6 cyl Four Wheel Drive Automatic
fuel pump wasnt pumping...replaced it and it works...now not getting a spark off plugs...replaced plugs, wires, distributor cap, and coil...still no spark
suggestions?
Aug 20, 2010 at 6:00 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Aug 20, 2010 at 1:12 PM
XOX_MEGZ_XOX
ok...replaced the distributor and now the fuel pump keeps running and running and running and wont stop when key is in on position and also jeep wont start
this all happened after the check engine light came on and was found to be the o2 sensor...didnt have time or money to replace so cut the wires and it started before wires were cut didnt start after...then put wires back together and replaced o2 sensor and still didnt start so then we did the fuel pump stuff
Sep 9, 2010 at 7:10 AM
