1997 Other Jeep Models engine stalls
1997 JEEP
131,300 MILES • 6 CYL • 2WD • AUTOMATIC
DALEJR88
My car has been stalling with in the past week. I had to replace the header because of a crack, figured that was the cause. I wasn't! I then replaced the crank shaft position sensor. That didn't help. I then replaced the idle air control sensor for the second time in 2 years. That didn't help. I then replaced the ignition coil, and distributer cap & rotor, none of those things seemed to work. It still stalls. It will crank at a cold start, with in 30 seconds it will stall. Sometimes we get spark in the plug wires, when the engine heats up and then stalls ,we do not get any spark after that. After a few minutes it will crank and run for a few minutes and stall, and the process continues. Any other suggestions?
Jul 22, 2010 at 2:02 PM
KHLOW2008
  • 41,814 POSTS
Hi dalejr88,
Thank you for the donation.
What is the model of your vehicle?
What engine and transmission variant is it?
Did you try to retrieve for trouble codes?
Jul 24, 2010 at 1:48 AM
