1997 Other Jeep Models
1997 JEEP
KANDIS
Electrical problem
1997 Other Jeep Models Four Wheel Drive Manual 137000 miles
I drive a 1997 Jeep TJ Sport. When I signal left, as soon as I touch the brakes, the signal light stops flashing and stays constant. If I let go of the brakes, it begins flashing again. When the brakes are engaged, the signal light on the front of the Jeep comes on. I'm not sure what needs fixing in this situation. I also have a 1989 Jeep YJ Laredo that has this same problem, only it happens with both signal lights. Please tell me what's going on. Thank you.
Jun 22, 2008 at 11:16 AM
BMRFIXIT
  • 19,053 POSTS
Check the bulb in the back
you may have the wrong bulb in or it was installed wrong
check that
Jun 27, 2008 at 11:04 PM
