1996 Other Jeep Models change
1996 JEEP
14,264 MILES • 6 CYL • 4WD • AUTOMATIC
JIMAX666
hi i have a 4.ltre grand cherokee with dana35 rear axle if i change this to a axle from a 5.2litre v8 which is also a dana 35 what sort of problem would i have if the ratio was different there both 1996 model and may be the same ratio i,m not shore please help thanks jim
May 15, 2010 at 2:21 AM
  • 31,937 POSTS
Hi there,
you can't run different ratio's front and rear diffs, in 4X4 you will bind up and damage the transfer.
mark (mhpautos)
May 15, 2010 at 2:39 AM
