1996 Other Jeep Models Brake lights
1996 JEEP
12,100 MILES • 6 CYL • 4WD • AUTOMATIC
JIMALL
On my 1996 Jeep Grand Cherokee Limited the brake lights stopped working.
The brakes seem to be working just fine.
I've replaced ALL light bulbs.
Where should I look next?
What is the most likley cause.
Nov 26, 2008 at 4:28 AM
MECHCURT
  • 184 POSTS
Hello; Sounds to me like it may be a fuse. Also some brake lights are fused thru another fuse. Is everything else working??? If all is checked ok i would look at the plug in under neath The light plug ins are under the inneer fender liner, There is a push tab retainer right at the corner of the vehicle. Pull this down and fold back. There should be a light plug in just above this sheild. Let me know where this gets you ok.
Dec 2, 2008 at 1:30 PM
JIMALL
It turned out to be the "Brake light switch" on the brake pedal.
thanks anyway.
Dec 2, 2008 at 1:47 PM
