1995 Other Jeep Models water flow
1995 JEEP
142,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCOOTBACK4
I just replaced the water pump on my 95 grand cherokee laredo. and the water is not flowing. I don't know what to do now
Oct 1, 2009 at 4:05 AM
MICKEY-D
  • 304 POSTS
If you are not letting the engine warm up enough for the thermostat to open, the water will look like it's not moving. Give it a chance. Let it run a while,it will overflow some if you filled it right to the top, but the level should go down when the t-stat opens. If that does not happen, replace the t-stat. Good luck. mickey-d
Dec 5, 2009 at 2:44 PM
