1995 Other Jeep Models no spark when trying to turn over eng
1995 JEEP
20,070 MILES • 6 CYL • 4WD • AUTOMATIC
CUBMYSTER
would trhe crankshaft position sensor not be working and were is it on the 95 jeep grandcherokee
Jun 21, 2009 at 1:21 PM
BMRFIXIT
  • 19,053 POSTS
Turn key on do you have check engine light on
you should
crank engine does light go off as engine cranking if not suspect bad crank position sensor
Removal
Disconnect sensor connector from main harness connector.
Connector is located near rear of intake manifold.
Raise and support vehicle.
Remove sensor mounting bolts.
Remove sensor.
Sensor is mounted on transmission bell housing.
Jun 21, 2009 at 1:46 PM
