1994 Other Jeep Models radiator and overflow compartment
1994 JEEP
JASMINE2001200011
Engine Cooling problem
1994 Other Jeep Models V8 All Wheel Drive Automatic
why would my 94 jeep grand cherokee limited v8's over heat instead of returning from the overflow to the radiator?
Aug 16, 2009 at 2:32 AM
MICKEY-D
  • 304 POSTS
Sooner, or later, the coolant an/or water will dissipate and have to be replaced. When the engine is cold, and not running, remove the radiator cap. Fill the radiator up slowly, until it is almost to the neck. Let it sit a few minutes, and top it off. Then fill your overflow tank to the proper cold level, and you should be OK.
Dec 17, 2009 at 3:05 PM
