1994 Other Jeep Models horn relay
1994 JEEP
TABBY
1994 Other Jeep Models V8 Four Wheel Drive Automatic
The horn suddenly quick working. The fuses are okay I checked them. I think it might be the relay is bad.Is there any way that you could tell me where that is located and how to change it.
Oct 7, 2008 at 9:25 AM
MECHCURT
  • 184 POSTS
First locate the horn and just make sure it is plugged in. The relay is under the hood in the power distribution center. There is a fuse #8 for the horn here and also the relay. Also in the fuse block you need to check fuze #15. If both fuzes are good the connection at the horn itself is good then check the relay. This can usually be done by just swapping it with another relay in the PDC. If this does not solve it i would begin looking at the contacts next under the horn button in the center of the steering wheel. hope this helps Pleaes vote and support us Curt.
Dec 2, 2008 at 3:49 PM
