1993 Other Jeep Models Sputters and dies
1993 JEEP
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
DEIDRE STEVENS
I have a 1993 jeep grand cherokee laredo. The problem is it sputters and dies. We had codes for the oxygen sensor, we changed that out. It still sputters and dies. We tried the map sensor it still sputters and dies. Were thinking fuel pump or fuel filter.
Aug 31, 2009 at 12:17 AM
MICKEY-D
  • 304 POSTS
I would try the fuel filter first, then pressure test the fuel system. This will tell you if the pump is supplying enough fuel. You might want to check the fuses and pump relay too.
Dec 17, 2009 at 1:27 PM
