1987 Other Jeep Models oil leak
1987 JEEP
167,000 MILES • 6 CYL • 4WD • MANUAL
DAKILLAKLOWN1
I purchased a 1987 jeep comanche last year, i have been hands on with working out the problems but it still leaks,i have replaced the oil pan gasket and rear main seal but it still leaks, i have taken it to multiple shops and none of them have been able to fix it, any suggestions?
Jul 11, 2008 at 7:23 AM
DOCFIXIT
  • 18,828 POSTS
Take a look at the oil pressure sender.
Jul 11, 2008 at 7:41 AM
RMASER
  • 11 POSTS
If the oil is still leaking in the area of the rear main seal and you changed the seal,did you take a good look at the crankshaft where he seal contacts the shaft,good be badly grooved.If that is where the oil is still coming from,they acually make a speedy sleeve for that area if the crank was out.
Dec 1, 2008 at 1:03 PM
