1983 Other Jeep Models Oil Pressure
CRP
  • 1983 JEEP
  • 6 CYL
  • 4WD
  • MANUAL
  • 117,000 MILES
My 1983 Jeep CJ5's oil pressure is around 50psi when first started and then drops to about 5psi after about 5 minutes. It has an oil sending unit that delivers oil through a tube directly to the gauge. When the engine is off it is possible to see the oil in the tube (which is opaque) drain back into the engine. Any ideas as to why the pressure drops?
Friday, January 11th, 2008 AT 2:42 PM
STEVE931
  • 12 POSTS
Most of the time this is due to worn rod or main bearings.
Friday, April 4th, 2008 AT 8:23 PM
