2007 Jeep Liberty HEADLIGHTS
30,000 MILES • 6 CYL • 4WD • AUTOMATIC
GJACKA6
HEADLIGHTS STAY ON, WHEN CAR IS NO LONGER RUNNING AND IS TURNED OFF.
Nov 8, 2010 at 11:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Will headlights change from low to high beams? Do the lights go off when you change them and then turn vehicle off? Seems like may have a stuck relay..
Nov 8, 2010 at 12:40 PM
GJACKA6
NO, HEADLIGHTS DON'T GO OFF, WHETHER OR NOT THEY ARE ON HIGH BEAM OR NOT. WE HAD TO DISCONNECT BATTERY TO TURN THEM OFF. CAR STARTS AND LIGHTS ARE ON, EVEN WHEN THEY ARE IN OFF POSITION.
Nov 8, 2010 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
okay, check for faulty relay, both low and high beam relays. both are on the junction block (below left end of dash). if the vehicle has daytime running lights then there will be no high beam relay, there will be a DRL relay in its place which can't be tested, just have to swap it with a known good one. if relays don't fix issue then the multi function switch will need tested.
Nov 8, 2010 at 3:09 PM
