okay, check for faulty relay, both low and high beam relays. both are on the junction block (below left end of dash). if the vehicle has daytime running lights then there will be no high beam relay, there will be a DRL relay in its place which can't be tested, just have to swap it with a known good one. if relays don't fix issue then the multi function switch will need tested.
Nov 8, 2010 at 3:09 PM
