hello
I change the oil every 3000k miles. Recently i noticed a yellow goop buildup on the cap and alittle in the filler houseing. I didnt notice any foam or discoloration in the oil that was drained. I recently replace the PVC value and 2 weeks later i noticed the yellow goop again. I heard a number of things that could be wrong: like scavenger hose blockage (not sure if my jeep has this hose), the oil i use is foaming up ( i use penzoil 5w-30), head gaket is leaking ( which i hope is not the case), i also heard it will go away once the weather warms up. I was hopeing you could give me a clearer answer. Thanks for your help
Jan 6, 2008 at 10:54 AM
