2005 Jeep Liberty yellow goop in filler cap
2005 JEEP LIBERTY
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
KEVYKEV14
hello
I change the oil every 3000k miles. Recently i noticed a yellow goop buildup on the cap and alittle in the filler houseing. I didnt notice any foam or discoloration in the oil that was drained. I recently replace the PVC value and 2 weeks later i noticed the yellow goop again. I heard a number of things that could be wrong: like scavenger hose blockage (not sure if my jeep has this hose), the oil i use is foaming up ( i use penzoil 5w-30), head gaket is leaking ( which i hope is not the case), i also heard it will go away once the weather warms up. I was hopeing you could give me a clearer answer. Thanks for your help
Jan 6, 2008 at 10:54 AM
BLACKOP555
  • 10,386 POSTS
sounds like the head gasket to me, to check that take off the radiator carp, fill up the radiator till the fluid doesnt bubble down any more, then start the truck and top it off again, if bubbles keep appearing then your problem is a bad head gasket.
Jan 6, 2008 at 11:04 AM
