2005 Jeep Liberty window motor
2005 JEEP LIBERTY
49,000 MILES • 6 CYL • 2WD • AUTOMATIC
COOKYMOM45
my driver's window will not close. i can hear the motor when i press the button, but the window will not go up.
Aug 28, 2009 at 1:00 PM
IMPALASS
  • 3,112 POSTS
Hello –
You need to remove the door panel to inspect. Most likely your window regulator cable is broken. Many times these come as complete assemblies with the motor attached. This is many times cheaper and……wiser…..if the cable broke the motor is just as old………replace both.
Aug 28, 2009 at 1:45 PM
IMPALASS
  • 3,112 POSTS
Hello –
Also, let me know if your model is the Limited, Renegade, Rocky Mountain Edition or Sport and I will check to see if you have any recalls that the dealer may fix for free.
Aug 28, 2009 at 4:06 PM
