2005 Jeep Liberty Shakes when accelerating
51,349 MILES • 6 CYL • 4WD • AUTOMATIC
PDASILVA18
My 05 Jeep Liberty shakes when I am accelerating past 40 MPH and gets worse as I reach 60 MPH. Its the entire Jeep that shakes and only when I am accelerating. It doesn't shake under 40 MPH nor when I have my foot off the gas pedal. Could this be a transfer case or CV joint problem? If not, any idea what it might be?
Mar 2, 2009 at 11:00 PM
JAMES W.
  • 2,394 POSTS
The first things you will want to check are the flex joints on both your drive shafts. A CV joint can be bad enough to vibrate yet, you still can't shake it like a regular U joint. So you need to look at them carefully. Also, it could be a drive axle joint or even a tire out of round with cord seperation.
Mar 3, 2009 at 9:16 AM
