I'm having trouble getting fuel into the tank. Checked the flow valve and it works find. Could a venting problem cause this
Jan 9, 2009 at 8:10 AM
✓Experienced Mechanic
This happens when the filler tube collapse which happens when the car is in heated weather and the EVAP system vacuums the tank. Here is a guide to help you see what you are in for when replacing the filler tube.
You may need to loosen the tank and let it down a little.
Check out the diagrams (Below)
Please let us know what you find.
Cheers
Images (Click to enlarge)
Feb 27, 2009 at 3:22 AM
SDALGLEISH12
MEMBER
1 POST
Yep that was the problem I had the job done for $160.00 and it works great thanks for the repair advice. I love this site.
