2004 Jeep Liberty idle adjustment
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
RSNELL1
idle is too low, when stopped or parking, the power steering pump is too slow, causing hard steering and the a/c compressor slows enough to blow hot air. I need to adjust up about 150 - 200 RPM. if i do this with the accellerator, it corrects the probolem.
Does the idel get adjusted through the computer or is there an idel adjustment?
Thanks
Aug 15, 2009 at 5:09 AM
  • 110,246 POSTS
The computer determines the idle speed.
Aug 26, 2009 at 3:07 AM
