fan switch only works on high speed, resistor?
38,000 MILES • 6 CYL • 4WD • AUTOMATIC
FPG
my fan switch only works on high speed. Blower will not spin unless in high speed
Sep 10, 2009 at 11:34 AM
  • 110,248 POSTS
This is common when the speed control resistor for the blower goes out here is the location so you can change it out. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 14, 2009 at 1:13 AM
VIRGIL REDFORD
the fan blower only works on the highest setting
May 23, 2020 at 5:16 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
Do you have a multimeter to do some testing?That way we can make sure its your blower motor resistor before replacing it.
SATURNTECH9
  • 30,869 POSTS
Also do you have auto climate control or manual temp control?
BILLY1252
My blower motor is bad-how do I remove and replace it?
  • 75,988 POSTS
How do you know its bad-could be a fuse/control switch/relay problem
Find the blower motor- turn heater on-bang on it a few times-did it work ?
BILLY1252
I have replaced all relays
BILLY1252
where is blower motor?
  • 75,988 POSTS
Its behind right side of dash on the HVAC assembly.
THOLMSTROM
how to replace a blower motor resistor switch
  • 75,988 POSTS
The blower motor resistor is mounted to the rear side of the HVAC housing on the passenger side of the vehicle.
Disconnect and isolate the battery negative cable.
Open the glove box door to gain access to the blower motor resistor.
Pull out the lock on the blower motor resistor wire harness connector to unlock the connector latch.
Depress the latch on the blower motor resistor wire harness connector and unplug the connector from the resistor.
Remove the two screws that secure the resistor to the HVAC housing.
Remove the resistor from the HVAC housing.
THOLMSTROM
Thank you very much!
BILLMIK10
  • 9 POSTS
2003, 3.7, 42,000 miles. A/C or heater fan only works in two, three or four not one. any ideas? some say its a resister pack or switch? where is resister pack at and how or what to check?
thanks
  • 55,658 POSTS
Yes, it sounds like your blower motor resistor is out this is located in the heater box near the blower motor. (speed resistor) please let me know. If thats okay the switch has gone bad but to be sure here is the wiring diagrams below so you can see how the system works.
Here are some diagrams (below) and some guide to help you test to confirm the problem and get it fixed:
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
BILLMIK10
  • 9 POSTS
Thanks for your answer, but where is this located? you say in heater box, Meaning? Where the motor is? or back behind the switch panel? and can it be checked with a ohm meter before i go buy one?
thanks
BILLMIK10
  • 9 POSTS
Okay, i replaced the part and its fixed thanks!
if others want to know where this resistor is see below:
How do you replace a blower motor resistor in a 2003 jeep Liberty?
Answer:
Open your glove box and empty it out. There will be two supports on each side of the glove box, push these towards each other and the glove box will kind of "fall out." It will still be hinged but hanging down far. You will then see a five wire connector going to a mount with two screws. Unscrew both of these with a nut driver, the whole thing will pull out. It is a credit card size resistor board. Unplug the cable from the resistor. This is what you need to replace to make it work correctly with one, two and three.
MADSHOPPER
Is this a dealer item? You have the same problem with my A/C on my 2007 Jeep Liberty. Position one and two do not work at all.
  • 55,658 POSTS
Yes, this is a dealer item only.
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
JAKESNANACAROL
Air Conditioning problem
2002 Jeep Liberty 6 cyl Four Wheel Drive Automatic
blower for ac/heat does not run on first 3 settings-only blows out on high
DANAUTHIER
  • 156 POSTS
This sound like a textbook example of a blower motor resistor failure. The resistor is what controls the speed of the motor, simply put the switch sends power though different curciuts in the resistor which changes the speed. The lower three settings slow the electicity, which slows the motor. The top setting is a battery voltage "pass through", the high speed will eventually fail is the resistor is not replaced.
The resistor is located behind the glove box and fairly easy to replace.
1) Disconnect and isolate the neg battery cable.
2) Open glove box door to access resistor.
3) Pull out lock on blower motor resitor harness
4) Press down on the latch on the blower motor resistor harness connector and dissconnect the wire harness from the resistor
5) Remove the two screws that secure the blower motor resistor to the HVAC housing and remove the resistor.
Reverse to install, torque screws to 17 in-lb (2 Nm)
This is the R&R from my database.
The resistor may be available from you local parts store but check the price at your local Jeep dealer as well, sometimes with electrical parts they are less expensive at the dealer and even if you buy them and install them yourself Chrysler parts come with a 12 month warranty.
Let me know if this helps.
Dan
JKOKINAKES
My fan control only works on highest setting (4) and 1-3 does not blow out any air. I've been told this is the blower resistor.
I had problems last month with hot air coming out of the A/C and it cost me $450.00 for a mechanic to repair. Did this have anything to do with the resistor?
What is the procedure in replacing the blower resistor?
  • 75,988 POSTS
