2004 Jeep Liberty Clunking
2004 JEEP LIBERTY
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOANNEJ39
i have an 04 Liberty 4WD that makes loud clunking noises when I put it in 4WD -either part-time or full-time. Also when I take off from a stop, something seems to be stuck and "let go" in the rear tires. Any ideas?
Feb 22, 2009 at 6:08 AM
  • 110,244 POSTS
Hi:
Does the noise go away?
As far as the rear, have the brakes checked. It sounds like they may be sticking.
Feb 27, 2009 at 2:42 AM
TWSCAT1
Does your Liberty have a limited slip rear axle and if so, have you changed the oil in it? The limited slip rear requires an additive or the differential will "grab" due to the clutches not releasing properly.
Mar 12, 2009 at 5:02 AM
