2004 Jeep Liberty
45,500 MILES • 6 CYL • 4WD • AUTOMATIC
LBROGAN1107
My key wont come out of the ignition. It stops half way and wont come out. i have to start it up multiple times to get the key out. eventually it will ruin my starter. what could be causing this problem?
Oct 31, 2008 at 6:23 AM
REDJEEEP
  • 29 POSTS
[quote:0f7389f9d7="lbrogan1107"]2004 Jeep Liberty 6 cyl Four Wheel Drive Automatic 45500 miles
My key wont come out of the ignition. It stops half way and wont come out. i have to start it up multiple times to get the key out. eventually it will ruin my starter. what could be causing this problem?[/quote:0f7389f9d7]
Your ingnition switch is jamed due to the tumblers in side the housing. you can spray some wd 40 in thier to help but you should replace the ingition cylnder before the key brakes off in side
Oct 31, 2008 at 7:31 AM
