2003 Jeep Liberty heater fan stop working
80,000 MILES • 6 CYL • AWD • AUTOMATIC
DAVID0417
My heater fan stop working all suddently, I check the fuse, the relay.The only things I didn't check is the blow motor, I suspect it the switch problem. Where is the blow motor locate?; if I want to check it.
Dec 10, 2007 at 1:28 PM
JEEP03
  • 21 POSTS
The resistor, located behind the glove compartment is bad, it has to be replaced.
Jan 3, 2008 at 12:19 AM
