Cigarette lighter fuse location
107,000 MILES • 6 CYL • 4WD • AUTOMATIC
KIRK HOOTON
What number cigarette lighter fuse?
Dec 27, 2009 at 6:27 AM
DOCFIXIT
  • 18,828 POSTS
Here is a guide to help you see how to test the fuse #F31 20 amp and the fuse location below:
Check out the fuse panel diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
Dec 27, 2009 at 6:42 AM
LAWRENISHA
One day my radio stopped working. So I replaced the fuse with a stronger fuse. Then it blew it again. Now no fuse works, they instantly blow. My radio, power locks, vanity lights do not work. I am wondering where exactly should I start looking to find the wire that is causing my problem. I have checked my radio wires and those are fine. I can fix the issue of I can find exactly where the problem is coming from. Also, my airbag light is on and I have never got into a car accident. My cigarette lighter still works and the port where I can plug in my phone charger still works. My locks only work when my keys are in the ignition.
Sep 24, 2018 at 12:51 PM (Merged)
