2003 Jeep Liberty
2003 JEEP LIBERTY
DANNYDREADS
Engine Mechanical problem
2003 Jeep Liberty 6 cyl Four Wheel Drive Automatic
start my jeep it stalls right away-start it again hit the gas for a bit-then it will run- seems like its taking longer to start .fuel filter? thanks
Aug 11, 2009 at 7:36 AM
  • 110,244 POSTS
Has the check engine light ever come on? Also, I would recommend checking the fuel pump pressure and fuel pressure drop off. Here is a how to. If the pressure drops off too fast, it will cause a harder start. It should hold pressure.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Aug 26, 2009 at 3:08 AM
