2002 Jeep Liberty REAR PASSENGER SIDE GLASS STUCK DOWN
2002 JEEP LIBERTY
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
RDDDDDD
HOW DO I SAFELY REMOVE THE INTERIOR DOOR PANEL TRIM TO GET TO THE GLASS
Sep 25, 2010 at 12:09 AM
BILLYMAC
  • 2,204 POSTS
the door panel is held on by plastic lock pins. use a wide screwdriver pop these pins all the way around the panel. look under the handle for hidden support screws
if you have power windows try and hold window switch down at master switch strike the door panel with your hand harshly. sometimes the motor has just stuck
Sep 28, 2010 at 12:33 PM
