2002 Jeep Liberty question...
20,750 MILES • 6 CYL • 2WD • AUTOMATIC
JOSE89
I Have a 2002 jeep Liberty 2wd with 020750 when I'm driving the truck the treuck goes to a side I asked a mechanic and he told me I need it alignment but then I ask a prefesional mechanic he told me to rotate the tires because the truck havent been used alot its seminew if you could answer my question
Aug 8, 2008 at 10:37 AM
BLACKOP555
  • 10,386 POSTS
could be the tires, but i dont think so, a alignment is more likely to cause that problem. you can try to rotate the tires and see, are they badly worn on the insides of one and outsides of others indicating that it could pull one way?
remember if the tires wear unevenly thers an alignment issue. which is causing the tires to wear unevenly in the first place.
Aug 8, 2008 at 1:22 PM
