checked the oil and the cap had a little discolor on it little cream color just a little not much
Jan 26, 2009 at 12:14 PM
✓Experienced Mechanic
Hi:
This is caused by moisture. Make sure the coolant level isn't dropping so we can eliminate the chance that it's a headgasket. If that is ok, chances are you need to replace the PCV valve. It's on the valve cover. When replacing it, make sure the hose attached to it isn't clogged.
Let me know what you find.
Feb 27, 2009 at 2:52 AM
