2002 Jeep Liberty brakes
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
THORNER
I have replaced the front rotors, calipers & pads on my jeep. I have a vibration occuring between 20 -30 miles mph whether I'm coasting or apply the brake. I have changed the drivers side caliper twice because a mechanic said it was sticking, It didn't effect the outcome. Although there is no ilight indicating a problem which of course could be a burned out bulb, can you suggest where to search for the cause?
Feb 27, 2010 at 8:58 AM
BLACKOP555
  • 10,386 POSTS
when vibration occurs throw vehicle in neutral. does that stop the vibration?
Feb 28, 2010 at 12:14 AM
THORNER
car still vibrates even after moving into nuetral
Feb 28, 2010 at 9:37 AM
BLACKOP555
  • 10,386 POSTS
could be transmission issue. put it in first gear and bring it up to that speed. does vibration still occur?
Feb 28, 2010 at 2:00 PM
THORNER
I tried your suggestion using both 1st & 2nd gear. I even changed the tire. Problem remains unchanged.
Mar 1, 2010 at 4:01 AM
BLACKOP555
  • 10,386 POSTS
if vehicle is rearwheel drive it could be due to the Universal joints wearing out.
if thats not it suspension should be checked for wear on the bushings causing movement.
Mar 2, 2010 at 9:49 AM
