AMELA21
I have a 2005 jeep grand cherokee and this morning when i was coming to work my car started making some weird noises and also i noticed if i drove faster than 40 mph the noise would start if i drive 40 mps or less it stops. Can you please tell me what the problem could be?
Nov 16, 2007 at 12:35 AM
TOBYU
  • 89 POSTS
It would be a good idea to keep it below 40 and keep the noise to a minimum until you get it checked out...
Continuing to drive it could cause a lot more damage.
Can you tell where it sounds like it is coming from? What area?
If it is 4x4 cycle it from 2-4wd a couple of times and end up in 2 wheel drive and back up a couple of feet... It would be a 4x4 issue or hub or transfer case issue...
Hard to guess without additional info.
On a vehicel that new...I would get it checked out ASAP
Nov 16, 2007 at 2:05 PM
