1995 Jeep Grand Cherokee Little Heat
NORMA
i have a 1995 jeep grand cherokee laredo,4.0 inline 6.i get very little heat from the heater.i have had thermostat replaced,and new radiator 2 years ago.i would replace the heater core but don't know how to get it out.please help :?
Aug 5, 2007 at 12:58 PM
  • 31,937 POSTS
Hi there,
I would flow test the heater core first, it may be blocked and a flush might do the job, also i would make sure the heater tap is opening all the way, you may be selecting hot on the dash and the valve is not opening fully.
Mark (mhpautos)
Aug 5, 2007 at 6:30 PM
Suggested Repair
Flow-test the heater core first; if it is restricted, a flush may restore heat. Also confirm the heater control valve opens fully when hot is selected before replacing the heater core.
Conversation Summary
The owner of a 1995 Jeep Grand Cherokee Laredo with a 4.0 inline-six reports very little heater output after a thermostat replacement and a radiator replacement two years earlier, and asks how to remove the heater core. The expert recommends flow-testing the heater core first because a blockage may be cleared by flushing, and checking that the heater valve opens fully when hot is selected.
