2009 Jeep Laredo Starting
LOPEZKLAN
  • 5 POSTS
Engine Mechanical problem
2009 Jeep Laredo 6 cyl Four Wheel Drive Automatic
Afther the first start my jeep does not want to start up again. I have to wait for some time for it to start up again why is this......
Feb 8, 2010 at 8:44 AM
SERVICE WRITER
  • 9,123 POSTS
When it is not starting does it crank and not start or not crank and not start?
IS there a security light on during any of this?
Feb 8, 2010 at 10:15 AM
LOPEZKLAN
  • 5 POSTS
Does not crank nor Start . Do not see any kind of light ?
Feb 8, 2010 at 11:36 AM
SERVICE WRITER
  • 9,123 POSTS
Okay that should eliminate a performance issue and anti theft.
We need to look at starting/charging.
Turn the head lights on when it is not cranking and the key is in the crank position.
What do the lights do, nothing? or dim?
(Depending on your mileage, you may be under factory warranty.)
Feb 8, 2010 at 11:24 PM
LOPEZKLAN
  • 5 POSTS
This morrning JEEP did not start at all and there is a light on look's like two lightning bolts.
Feb 9, 2010 at 7:43 AM
SERVICE WRITER
  • 9,123 POSTS
Hmmm...Lightning bolts huh?....
Not sure I've seen that one yet....Check the owners manual....Charging system? Might be...might be the direction we are going in, but I was expecting starting system...
Can you post a pic too?
IF you turn the headlights on, were they bright? Did they change when you tried to crank it?
Feb 9, 2010 at 10:36 AM
LOPEZKLAN
  • 5 POSTS
Going to take it in to the auto shop. Thank you very much for your time......
Feb 9, 2010 at 11:04 AM
SERVICE WRITER
  • 9,123 POSTS
You may be under factory warranty with this, so call the dealer if you are.
Sorry for not being familiar with the lights you described, but we were going in the right direction.
Post back with what happened, good luck.
Feb 9, 2010 at 11:11 AM
LOPEZKLAN
  • 5 POSTS
Agian I like to thank you for your time. This is what Jeep said it was that the wcm went to sleep and had to reset and flash the wcm and pmc. Program with wcm with new updates. Jeep is working good so far ? Thank you Mr. Lopez
Feb 12, 2010 at 2:44 AM
SERVICE WRITER
  • 9,123 POSTS
Software update..huh....good thing you took it in and Thank-you very much for updating the post!!!
Feb 12, 2010 at 3:01 AM
