2006 Jeep Laredo starting problems
KCORLE
Electrical problem
2006 Jeep Laredo 6 cyl All Wheel Drive Automatic
My 2006 Jeep Grand Cherokee Laredo will not start or even turn over even after i replaced the battery but it will start if i jump it with another vehicle. Although it will sometimes start randomly usually when it is warm.
Jan 8, 2010 at 5:24 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd have to make sure the battery has a full charge and the battery connections are clean. I'd check the charging system. When the problem occurs, if it won't even crank, watch the lites, dash--dome--headlites-- something, with the key in the start position, if the lites stay bright, no reaction, sounds like an open circuit to the starter. I'd also want to check for voltage drop along the starter circuit.
Jan 8, 2010 at 6:45 AM
