2005 Jeep Laredo Door Locks
144,000 MILES • 4 CYL • 4WD • AUTOMATIC
SUEZUR
I am only able to open the driver door lock via the remote, key lock and power button in the vehicle. If I roll down all the windows and manually pull all the buttons up, the doors will lock automatically due to the 15mph safety and they will also lock via the remote. The locks go down but will not open no matter what I do. I can not access the lift gate at any point due to its always locked as well and there is no button to unlock it manually. This is a horrible inconvienience and need some guidence.
May 12, 2010 at 3:29 AM
2CARPRO JACK
  • 11,533 POSTS
Try pressing the "unlock" button on your remote twice in a row.This should unlock all doors.Newer cars usually only unlock the drivers door when you press the button once, to keep others from getting in your car from the passenger door
May 18, 2010 at 6:25 AM
2CARPRO JACK
  • 11,533 POSTS
Your post is a little confusing to me.Is the problem that the unlock wont work on the power lock switch for all doors?
May 19, 2010 at 6:48 AM
