2004 Jeep Laredo DRIVER SIDE WINDOW AND LOCK CONTROL
73,000 MILES • 6 CYL • 4WD • AUTOMATIC
GIGYANI
NOTHING WORKS ON DRIVER SIDE CONTROL PANEL THE WINDWS ARE OPEN SO URGENT RELIEF SOUGHT PLEASE
May 18, 2008 at 10:57 AM
RLTIPTON
I had the same problem. If you take the rubber boots off between the door and the body frame you will see that one of more wire is cut. It appears as to the wiring harness is to tight and the wires eventually give out and have to have short length inserted to extend the wires.
Hope this helps.
Rick
Jul 5, 2008 at 10:03 AM
