2003 Jeep Laredo where can i find
BUFFALOCAM
Engine Cooling problem
2003 Jeep Laredo 6 cyl Two Wheel Drive Automatic
i am looking to find the fuse to my cooling fan and i dont have the diagram. my cooling fan just stopped working and i want to see if it is the fuse that went out?
Nov 17, 2009 at 4:49 AM
BEEF99
  • 152 POSTS
Find out how many ohms you should have at the fan to see if you have a continuity problem and if not, then your fan is bad. You will need an ohm meter to do so. If you are dead set on checking fuses, they may be under your hood or under your dash or by the passenger side kick panel. Under the hood you will have fan relays if I remember right, this could be the problem too and they are inexpensive to replace....especially if you go to a junk yard and get one. Hope this helps. good luck and god speed.
Nov 17, 2009 at 1:10 PM
