2002 Jeep Laredo cooling fan not kicking on
WOLFED16
Engine Cooling problem
2002 Jeep Laredo 6 cyl Four Wheel Drive Automatic 130k miles
My cooling fan is not kicking on, i am going to check the relay and wire the fan to see if the motor is ok. My a/c would not kick on however since the fan quit working. If i get the fan fixed should this fix the a/c problem?
Jun 15, 2010 at 11:48 PM
HUXLAY
Discussions are always the main source of accurate information and to ensure a comfortable results, you can get immediate and reliable information, which will definitely help you in every area of your concern.
Aug 1, 2010 at 11:31 PM
