2002 Jeep Laredo car keeps cutting off
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALLYJEEP
did a whole tune up......change the crank shaft sensor/fule filter/plugs and wires/camshaft sensor
Jun 29, 2009 at 1:35 PM
LEGITIMATE007
  • 5,121 POSTS
have you checked the idle air control valve, and did a throttle body cleaning? does this happen when coming to a stop or idling or turning corners, if it does then your iac is mostlikely the culprit
Jun 29, 2009 at 2:28 PM
