Did a whole tune up. Change the crank shaft sensor/fule filter/plugs and wires/camshaft sensor
Monday, June 29th, 2009 AT 8:35 PM
LEGITIMATE007
MECHANIC
Have you checked the idle air control valve, and did a throttle body cleaning? Does this happen when coming to a stop or idling or turning corners, if it does then your iac is mostlikely the culprit
