2002 Jeep Laredo
2002 JEEP GRAND CHEROKEE LAREDO
11,200 MILES • 6 CYL • 4WD • AUTOMATIC
SHERRYCOVER
What would be the first thing to check when getting the 455 code, would this have anything to do with the mechanic taking the fuel tank out and replacing anything with the fuel line or filters.
Mar 30, 2010 at 2:33 AM
BEEF99
  • 152 POSTS
Your engine does not have a return line going back to the gas tank so that is not your problem and if you did nto get this code before taking it into them, I would be suspect that it could have been something they did. If not, then it is a seperate problem that needs addressed. The first thing to check is you Evaporative system under the hood and check for leaks in your lines as well as the round small tank.
Mar 30, 2010 at 5:01 AM
